Reno - Demo'd window opening showing in elevation
After switching to AC 18 from 17 noticed an issue.
Demo'd windows show in elevation as a solid line, where the window was.
There is a rectangle where the window opening was. It appears as a solid line, the pen color is the wall's "Uncut Line Pen" color.
The renovation filter settings are set to New Construction. And demo'd objects are set to Hide, for this setting.
In our previous version, the demo'd window would be hidden.
Has anyone experienced this?
Another option to hiding the rectangle, would be to make it a dashed line. This is actually a drawing standard for us, to show removed windows as dashes in elevation. So we can call it out as new wall.
David Maudlin
2014archicadguy:
In the Renovation Filter Options, change the New Elements from Override to Show.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
this worked thank you!
Stress Co_
This would be a helpful option.
I assume the easiest work-a-round is 2D lines?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
