Renovation Filter in Detail View Settings
Syncop8r
I know this has been discussed here before but I cannot find a solution.
I wish to change the Renovation Filter in the View Settings of my Details but cannot.
Currently running ArchiCAD 23 on WIndows 10
4 REPLIES 4
filip
Open the view, change to the desired filter, and then right-click on the view and choose "Redefine with the current Windows Settings"
Syncop8r
Thank you for your reply.
Unfortunately when I do that it does not save the view with the chosen Renovation Filter, it just reverts back to "NOT IN USE".
Hi Syncop8r, were you able to resolve this issue? We are encountering the same issue in AC25. Thanks in advance.
AC25
iMac 27 | macOS Cataina
Processor | 3.6 GHz 8-Core Intel Core i9
Memory | 24 GB 2667 MHz DDR4
Found the workaround;
https://community.Graphisoft.com/t5/Document-Visualize-forum/Can-t-amend-renovation-status-in-viewse...
AC25
