Renovation Over rides - Shadows don't show up on "existing" elevational walls?
rob2218
So..in a nutshell, shadows aren't showing up in walls that are left in an "existing" state, yet once a new window, door, opening, removed window in a demo state is created....then the shadows on the walls in their existing states....show shadows...........what's happening here?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
7 REPLIES 7
I’ve had this before and for the life of me cannot remember how I got round it. I’ll dig out the file I fixed it in and post it here. Comment back if you haven’t seen it by tomorrow to remind me.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
much appreciated for the help.
I'm sure it's a renovation filter option setting that I just don't have it set right.
thanks,
i>u
Edgewater, FL!
SOFTWARE VERSION:
Any luck on finding how you resolved this?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Assuming I have understood what you are trying to do correctly I think the issue is that you need to tell the Renovation Filters for the Existing Graphic Override NOT to override drafting fills. See attached screenshots.
Lee Hankins
Screenshot 2022-07-29 at 15.58.57.pngScreenshot 2022-07-29 at 15.58.53.pngScreenshot 2022-07-29 at 15.59.02.png
Lee Hankins
The shadow appears to be overlaid on the elevations as a drafting fill.
Lee Hankins
THANK YOU LEE.
it was indeed these settings as you pointed out.
Seems somehow these settings I had them off/tweaked/messed with...whatever...and thru my entire shadow fill patts off. this did the trick. thank you.
i>u
Edgewater, FL!
SOFTWARE VERSION:
