Renovation filters - Composit wall
Renovation filter in AC is great, but is there a possibility to filter composite wall? In my case, I have naked brick walls and I need to dress them with insulation and plaster.
I guess, there are no way to specify renovation filters in making composite structures.
If I am right, AC, please, make sense for renovation.
It is not enough to specify core, finish and other. We need renovation in composite structures.
It is a big trouble to draw core, then draw other wall as insulation, to cut windows two times.
Discussed and wished for at length over the past couple of years. Graphisoft is aware of how much we all want to see this feature for skins.
Some of the wishes:
http://archicad-talk.graphisoft.com/viewtopic.php?p=208002
http://archicad-talk.graphisoft.com/viewtopic.php?&t=36956
Some of the topic threads:
http://archicad-talk.graphisoft.com/viewtopic.php?t=40530
http://archicad-talk.graphisoft.com/viewtopic.php?p=212663
http://archicad-talk.graphisoft.com/viewtopic.php?p=207924
http://archicad-talk.graphisoft.com/viewtopic.php?&t=37046
One of the forum moderators
Thank You very much for Your response.
I made my search not enough.
