Revision cloud bug turnes into drawing of sheep
Jean
Hi all,
Was just editing my revision cloud and this happened:
I just undid it and it solved the problem but had to save it and see if anyone has had this happened to them.
Before the sheep appeared:
Was just editing the nodes for the revision (might have right double-clicked it or something) and the sheep pop out.
Plus it looks pretty cool
Miha_M
That is one of many easter eggs hidden in Archicad!
Easter Eggs in Archicad - Graphisoft Community
| Archicad 4.55 - 27
ryejuan
you need to try the tetris. 😎
In the end what is your Objective?
ArchiCAD 9 onwards
Rob
this looks like an unhandled exception in inputted values in GDL script (cloud is essentially library part). in other words you could set values of GDL parameters (e.g. moving the diamond hotspot) to a value that is outside of (logical) range which in turn caused collapsing the cloud shape calculation. eventually you could keep this as is... it would definitely bring anyone's attention to the revised detail.... which is essentially the purpose of clouding. 🙂
::rk
