How do you like to draw roof plans? Do you use the roof element and fill in the roof planes with a solid fill, or do you do 2D line work (or is there a 3rd option)? I am trying to reduce the 2D line work and be more efficient, but even in 3D in the case of a very complex roof with several levels and dormers, it is very cumbersome to try to get all the roofs in the correct "display order" to make it appear as you would see it from top-down.
I also like to indicate where roofs overlap with a dashed line showing where there is roof below...any recommendations?
Thanks!
ArchiCAD: AC26, Version 4024 USA Full (Apple Silicon)
Computer: 2022 Apple M1 Max, 10-core CPU, 32-core GPU, 64 GB memory
