Roof Slope is Not Correct
Eric Milberger
On hte attached - I have placed a truss which matches a dashed line - both drawn at 4/12 slop
The roof is also drawn at what is shown as 4/12 but is NOT at 4/12
Eric Milberger, Architect | Master Planner
3 REPLIES 3
Eric Milberger
Here is the picture
Roof pitch can be input as an degrees or percentage.
How did you input a 4/12 pitch?
You can use the pet palette in section to adjust the pitch to match the truss/line.
Eric Milberger
I put in the pitch. Something was stuck in the element that was created.
I created another and it worked fine. I compared all info boxes and all were the same with different results.
Learn and get certified!
