Roof not showing in layout (Solved)
Kenneth
The roof was showing yesterday, but now it is missing. It shows up fine in 3D and when I work on the roof storey.
EDIT: Solution in case anyone gets the same problem. At the place I was in the picture, right-click the house. Then click on "Modify Source View Settings". Then change the Layer combination to 3D Documentation/Visualization.
jl_lt
Ace
Hi. Did you insert this drawing into the layout from the view map or the project map?  If you did the latter you will keep getting it changed.
Kenneth
Can't remember, I think View map. Is it supposed to come from Project map?
Hi, no, from the view map
