Document & Visualize forum
Roof rafter dimensions in Schedule of Elements
Voytek
Could some please advise how do I get dimensions of a roof rafter, such as: (1) Profile Height (rafter height), (2) Profile Thickness (rafter width) and (2) Lumber Size (rafter length) in Schedule of Elements. The rafter is sourced from Archicad Library 25 > Roof Construction 25 > Rafter 25. These dimensions are shown under PROFILES SETTINGS > Dimensions...
So far, I could only generate a Schedule showing: Profile Thickness (corresponding with the rafter width) and "Height" (which does not correspond with rafter height).
ArchiCAD Versions 5.0 - 25 (except 19) - Windows 10 Pro for Wokstations - Lenovo P70 - 2.8GHz Intel Xeon - ThinkPad Display 720 x 1280
2 ACCEPTED SOLUTIONS
If these are parameters in your rafter objects,
Then in the schedule settings, there is an option to add parameters.
You then need to browse for the rafter object and the parameters you want to add.
If you can't figure it out, let me know - I don't have Archicad available at the moment so can't show screen shots.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Thank you Barry. It worked. Much appreciated.
Voytek
Versions 6.5 to 25
Voytek
