STOREY ELEVATION
Llian
The lowest level is at 25.00 m above sea level. I can't seem to enter 25.00 into the storey...and I have set the project reference level at 25.00 m sea level.
I tried typing 25.00 at P3 Elevation but it keeps reverting to 5.50.
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
4 REPLIES 4
Llian
the project section elevations....
Lilian Seow
LEED AP | cSBA
Llian
project location set at 25.00 sea level...
Lilian Seow
LEED AP | cSBA
rule number 1, you can't make the elevation of a lower storey higher than the elevation of a higher storey.
try typing 25.00 into height to next, then change the elevation 25.00....
As i rule when i do tall building, it was ground at storey 0, basements on negative storeys B1 is -1, B2 is -2, etc.
Stress Co_
Elevation in Story Settings isn't the Elevation above sea level
(well,... I guess it can be).
Best practice in my opinion (and as allanp noted) is to set a datum story to Zero in the story settings.
You may find, it makes your reference levels easier to navigate.
A word of CAUTION if you're far along in this project.
Changing the Sea Level-Story settings can wreck havoc on
the model/saved views.
Make a back-up before you make changes.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
