2014-09-02 01:02 PM
2014-09-02 01:25 PM
2014-09-03 06:07 AM
Statari wrote:Since the Marker is opened from an .lcf file, it is not editable, but you can Save As... a copy to have an editable version (which you should do anyway so the edited part with a different name and GUID is kept separate from the standard ArchiCAD Library, the new one should be part of your office library). This library part is a Marker (Subtype: Window Marker), and you can change the default parameter values in the Parameters Window of the main Library Part window.
I was hoping I could at least open the 'W Marker 18' object so I could just edit the parameters I care about but even though I went through the window marker sub-type, it was un-editable but... also represented by an actual window, not a marker.
2014-09-03 09:58 AM
