Document & Visualize forum
Scale of 3D view of elements in a schedule
gdford
When click on a column of a 3D view of an element in a schedule, and then in the schedule dialog box I change the scale of the 3D view, the schedule does not remember the scale selected and reverts back to the default view the next time I go to the schedule. Is there a way to get this to stick?
I have the schedule set up in the view map and after making the change in scale to the 3D view I resave the settings of the View in the view map, but this does not make the change in scale stick.
Any Thoughts???
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
I have never tried setting the scale in the cell.
I am not sure why that doesn't stick if you can set other things like alignment of text size, etc.
I set the scale in the 'View Settings' for the schedule.
That will stay as you set it.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Tim Ball
If you change the schedule scale in the view map it should solve it
Tim Ball
AC25, iMac
User since V5
