Scale of 3D view of elements in a schedule
gdford
When click on a column of a 3D view of an element in a schedule, and then in the schedule dialog box I change the scale of the 3D view, the schedule does not remember the scale selected and reverts back to the default view the next time I go to the schedule. Is there a way to get this to stick?
I have the schedule set up in the view map and after making the change in scale to the 3D view I resave the settings of the View in the view map, but this does not make the change in scale stick.
Any Thoughts???
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
2 REPLIES 2
I have never tried setting the scale in the cell.
I am not sure why that doesn't stick if you can set other things like alignment of text size, etc.
I set the scale in the 'View Settings' for the schedule.
That will stay as you set it.
Tim Ball
If you change the schedule scale in the view map it should solve it
Tim Ball
AC26, iMac
User since V5
Learn and get certified!
