Visualization
Scale texture with Cinerender engine
Achille Pavlidis
Is it possible to scale textures when rendering with the new Cinerender engine, as it is possible to do with the Internal engine?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Not sure what you mean. Do you mean to set the physical horizontal/vertical size of the texture? If so, then yes... I can post a screenshot if you're not seeing the setting.
One of the forum moderators
Achille Pavlidis
OK, I found it
Thanks Karl
