Project data & BIM
Schedule Components (Skins) Weird Behaviour
I am trying to get the area and volume of each skin in a custom schedule, and it works perfectly fine with a plain wall, but for the walls that have openings, the schedule duplicates some skins.
For example I would have Brick and Insulation twice with the same area, but the Cement screed would appear once as expected.
Thanks you!
1 REPLY 1
Could you post a few screenshots that would illustrate this problem?
Also, could you state your Archicad version and system configuration? It is useful info, you can put it in your Signature.
