Schedule Criteria based on if element is Classified
Josh Verran
It would be good if there was a criteria in schedules that was something to the effect of "if the element is classified include it".
You can filter if an element is in a branch of a classification scheme, but you would have to have as many of these criteria lines as you do classification branches (hope that makes sense).
Our work around is to create a property called "is classified", make that property available for all classifications.
In the schedule add criteria that if the property "is classified" is "available" then include.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
Does classification 'has value' work?
Would this include any items that has any classification?
Josh Verran
You're a legend! Can't believe I've overlooked that option.
Appears to work, I'll comment back if there's any issue.
