Thanks Minh,
The shortest marker is greater than 40' long and the longest marker is greater than 110' long. For what it is worth these are the Build-In Section Markers and as I mentioned this is a V24 project and I am viewing the bimx on an ipad pro. I changed out the section markers to the v24 section marker but that did not make any difference.
Also - I discovered that when viewing the same bimx export on an android device the markers are visible.
I removed the bimx app from the ipad pro and reinstalled but the markers still do not show up.
Older pre version 24 bimx models that have section markers are visible on the ipad pro.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
Win 10 - ASUSTeK Zephyrus M GU502GV - 64 bit
Intel(R) Core(TM) i7-9750H CPU @ 2.60 GHz
16.0 GB ram
