Section marker setting not saved in favorites
Hi.
Running AC19 #4013. Whenever we open/start a project the section/elevations are set to place unlinked marker. Unfortunately this setting is not saved in favorites. We want favorites that are preset to create a new marker. Is there any fix to this?
Regards
Alexander
1 REPLY 1
Erwin Edel
I think if you set up the section and elevation tools (regardless of favourites) in your template to be creating views, it defaults to this if you activate the tool after starting a new project from the template.
Picking a favourite might make it jump back to unlinked though, no experience with it.
We have some sections / elevations setup in our template and generally copy them around or use syringe to pick up settings.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
