Similar to the 'air perspective' from the sketch render then, I assume?
I would actually suggest 'distance fog' in the cinerender detailed settings. I know you explicitly said it had to be a surface setting, but this does exactly what you describe. You can untick 'affect background' to keep your environment background clear.
Just did a quick test with a white colour and fairly high distance from the camera you can wash out the colours that are far from the camera. Try playing with the strength setting too.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
