Interestingly (i.e. I would consider this a bug) if you set the elevations to show shadows "as in 3D window" and then create a new view and place this on a layout then that layout view will remember the shadow settings.
Now change the sun position and open the same elevation (rebuild if necessary) and you will se the new shadow.
Save this as a view and place on a layout.
Do this again as many times as you want.
The drawings on the layouts will all remember the set sun position.
But if you open the source for these drawings (i.e. the actual views) they will all have the same shadow as set in the current 3D projection settings.
So the views will all look alike but the drawings on the layouts will all be different - even if you 'update' them.
