2013-02-2101:31 AM - last edited on 2023-05-3010:05 AM by Rubia Torres
Is there a way to show the section markers in their correct location parametrically?
I want to drop some section markers in plan and have them show up in elevation? I know I could trace reference the plan then place a linked marker but I wonder if there is an more dynamically connected method.
No it isn't working and I can't remember if it was ever a feature that showed up. It would be similar to the grid lines showing up in both plan and elevation, instead with the section markers.
I'll take a look when I get the chance. (I hope I'm remembering correctly and not getting it mixed up with Revit.) It may have to do with the markers you are using.
I think you will have to place a linked Marker, I am not aware of this possibility of a Section Marker automatically showing in a perpendicular Section/Elevation. Would be nice though.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
