Document & Visualize forum
Since the save as option for BIMx was removed
How do I export my model without publishing it to the web, if I just want to save a BIMx desktop viewer file.
There should be away to save BIMx files anytime then upload them using an upload function under BIMx website.
The save as is the only way I can see to do this.
Can anyone explain why this feature was taken out of the save as menu?
Can we add an option under publish to save to drive, that doesn't look for graphisoft ID or any internet services?
Additionally there is no option to render GI once saved in BIMx the only way is to publish it and choose the option when publishing it.
22 REPLIES 22
Hi there,
You can publish BIMx models locally by setting Publisher Properties to 'Save Files' with the Create a single file option checked. I've attached a screenshot for reference.
Kind regards,
Marcus
Yes, I am aware of that option but you still don't get the same results as before.
Marcus_Scott wrote:
Hi there,
Kind regards,
Marcus
Yes this could become a problem
previously with the save as .bimx file option it would take far less time
Also, when you open the file with the bimx viewer there is now no way to resave it with adjusted setting changes within bimx
We would previously turn the shadows on and adjust the view cone or head height to suit each model so that when the client opened the final file the job was as we intended to view it.
the client should not be expected to go in and change these settings, this is just ridiculous, why does graphisoft intend on changing things that worked perfectly fine beforehand.
Exactly what I was thinking! Now I have to go back one version to save a normal BIMX file.
I dont suppose archicad has created a fix for this yet??
We would like to be able to adjust view cone or head height of a bimx model and the illumination do for example 'architectural white' only
and then distribute to the client, the client should not expect to change or even know how to change these settings.
Is there a fix for this yet Graphisoft?
Hans Roest
I have been watching these topics like a hawk as this is also one of our big issues with AC20. Seems AC doesn't make a priority of this...
BIMx is basicly a worthless add-on at the moment, only suitable for in-office presentations, not for sharing files with clients.....
apparently if we want graphisoft to implement changes in their software we need to create a 'wish' for it and if it gets enough votes it may get implemented:
http://archicad-talk.graphisoft.com/index.php?c=6
In the BIMx app there is a "Feedback e-mail" link.
Give that a go.
Hopefully it will be considered and not ignored.
Who knows - you may even get a reply.
Let us know if you do.
Versions 6.5 to 25
vfrontiers
Before I head off to the WISHES category... Just want to ECHO the sentiments about SAVING changes to the BimX settings after creating..
If GS won't allow that... then PLEASE allow us to set those settings in AC prior to PUBLISHING...
Duane
Visual Frontiers
AC22 6021:|: AC24 4007:|: Enscape3:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
vfrontiers
Also, while I'm here...
I can't save two different BimX's in the same PUBLISHER SET????
They will be named the same thing and overwrite each other...
Am I seeing this correctly?
I've spent some time creating TWO (or more) versions of my files... One as a PRESENTATION piece and the other as a GHOST w/ FRAMING showing thru...
Yes, I can use TWO different publisher sets... but just seemed odd...
Duane
Visual Frontiers
Wokka
Give that a go.
Unfortunatley the feedback email link doesn't work for me.
It really seems to be 1 step forward, 2 steps back with this version. I can't understand 2 major points:
- You can't save the file, so the client needs to learn all about sun, shadows etc
- Being forced to choose GI before generating the file, and the additional time in rendering. I think the renderings are a bit better, but we no longer have control over the quality. We usually open the bimx, check for errors, the hit the GI button. Now we have to publish the file first, check it, and even if it's OK, we still need to re-publish.
Am I missing something???
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
www.3de.com.au
> Windows 7 Pro 64bit
> i7 CPU 920-2.67Ghz
> 6GB RAM
> ATI Radeon HD 5700
>ArchiCad 4.55>20 AUS
>Cinema 4D R18
>VRAYforC4D R1.9
I get a pre-formatted e-mail ready to be filled in.
Or are you saying the e-mail doesn't get through?
Versions 6.5 to 25
Sorry for the late reply but I thought I'd chime in with another PLEASE. Removing the ability to save/set prefs for a BIMx file is just staggeringly misguided.
PS This may be old news but I did talk to AC-support about this. BIMx has been spun off on it's own development path. So ARCHICAD support plead that it was out of their control.
PPS And I also did use the BIMx email feedback feature and did hear back from a BIMx person. I explained our "save with adjusted sun/shadow/stationpoint settings for our clients" workflow. They seemed to understand - but confidence was low on my part because at first they seemed surprised this was a problem for us! Fingers crossed for a fix.
Any many apologies for the multiple instances of this post! >embarassed and ashamed<
Eduardo Rolon
Don't worry. I removed the duplicate posts.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Katalin Borszeki
Hi All,
We are currently not planning to re-establish the saving option from inside BIMx. We are developing towards differentiating the Authoring application and the Viewer’s funtionalities. I hope this responds to your current questions about the disappearance of some of the options. Best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Wokka
KatalinBorszeki wrote:
Hi All,
That's fine but quiet often it's just the author that needs to see the bimx. I just found I can't publish without an internet connection, ie it refused to save the local file, and as I am often in remote locations, the internet is dodgy. It just seems way to complicated to create a simple rendered , 3d model that we could do 5 years ago... We are just single operators trying to show our clients their house, that's all. Simple, please
www.3de.com.au
> Windows 7 Pro 64bit
> i7 CPU 920-2.67Ghz
> 6GB RAM
> ATI Radeon HD 5700
>Cinema 4D R18
>VRAYforC4D R1.9
We just recently made the jump from 19 to 21, and frankly the changes to the Bimx program is an absolute disaster. We have all of our clients and consultants using the viewer to help them understand the project and coordinate their work with ours. Being able to save all the preferred setting and having everything ready to go right when others open our model has been invaluable in terms of communication and productivity. Many of our clients do not find the interface intuitive, and having to change multiple settings every time they open a model is frustrating for them, and it wastes our time as we are now answering calls regularly just to help people use the software. Unless this is fixed, or a reasonable work around is found soon, we'll be abandoning 21 and going back to 19 until Bimx is useful again. I understand Graphisoft wants to distinguish the viewer and the authoring programs, that is fine and would work for us. Instead they have taken away a basic and fundamental functionality with no alternate method of achieving the same results. This would be like if there had been no stair tool at all in 20 - because they were working on a new tool for 21. A bad business decision, and disrespectful to all archicad users, to eliminate a such a basic function.
Hans Roest
Hear hear!! Exactly our point (ever since AC20)
It's fine that you want to discontinue rendering and saving in de BIMx viewer app, but PLEASE give us a way to save default settings for the BIMx models (eg. Sun Shadows on)!
Labels
