2010-10-2801:39 AM - last edited on 2023-05-1112:10 PM by Noemi Balogh
Hey Guys,
When doing a render with the sketch engine, i cant seem to get the settings right.
can anyone help me with some settings to get a good sketch render.
Cheers
Most of the defaults are pretty cartoony. I have found it best to start with "Koh_I_Noor" which is pretty tight and crisp (though a bit too hard line for many purposes) and then adjust to what you want.
Unfortunately you can't save your custom settings in the dialog. The workaround is to make a 3D view with your custom sketch settings active. You can name the view accordingly and use it to revert to those settings.
