Sluggish when panning
Too Long
Ive noticed sluggish or laggy behaviour of late. Even more so with a trace active.
I wouldnt rate my machine as slow, the CPU only uses 30% when panning around, I have 64gb of RAM and a RTX3090 GPU.
Any tips to increase performance?
Could this be to do with the drive that contains the library maybe?
AC26 AUS Full
First of all you should use "Structural Contours Only" in Advanced redraw options, this will greatly increase PAN speed in plans and sections. For me this is MUST setting in work environment. Also max our RAM usage 😉
If you use Trace reference it will slow down you computer in most cases, so use it when you only need it 😉
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v26 INT / NOR (5002)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
WOW what a difference that made.
Thank you so much
AC26 AUS Full
