Visualization
Split Textures
muzedesigns
Is there any way to colour walls with split textures without having to horizontally split a single wall into two walls.
For example:
I have a 3000 high wall;
0 - 2100 is a shade of grey.
2100 - 3000 is white.
any ideas?
Chrissy
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
9 REPLIES 9
Dwight
Yes: map this to a material size the height of your wall.
Dwight Atkinson
Dwight
Stripe on wall
Dwight Atkinson
Dwight
The settings, starting with the Internal engine.
It is mapped to the height of the wall, in this case 2.0 m.
Use 3D align to position it exactly to match the sill position.
Plenty more tricks like this during my day long seminars next week:
Washington DC - Monday
Philadelphia - Tuesday
New York -Thursday
Boston- Friday
Dwight Atkinson
Dwight
Since you might not have Photoshop, here's the actual file you'll need.
Dwight Atkinson
Link
The good Karl O wrote an article on this here: http://www.archispectives.com/tips/tip2006-05.htm
Link.
Dwight
Thanks, Link, I should have remembered it.
However, the "LightWorks Bug" referred to in that piece has been fixed.
Dwight Atkinson
muzedesigns
Dwight! Thank you so much!!
I have your book and love it!
You should come visit us down under - I would love to attend some of your seminars if you ever come to Sydney!
Chrissy Avramidis
muzedesigns
Great! Thank you Link!
You guys are so helpful!
Cheers!
Chrissy Avramidis
Hi guys,
How about this:
Create a Profile for a Wall. The Fill in the Profile Manager should be created in such a way that its vertical sides are created from two segments (node in the middle). Then the lower segments are assigned a different material on both sides and that's it. Save it, use it.
You can even set the vertical stretch range so maybe the lower band is always 2 feet high, while the upper band stretches as the Wall's height changes.
