Document & Visualize forum
Spot Elevation on a Slab below Floor Zero
pedrocollares
Hi there,
I'm attempting to place a spot elevation marker on a Slab that came with an IFC hotlink.
Such slab is attached to the floor plan I'm viewing, but since it is at -0,10 level in relation to that floor plan, it isn't visible and won't show as an option to place a spot elevation.
The only way to apparently make it show is setting the view depth to include +1 floor below (Merely incuding a 0.20 bottom offset doesn't work), but I need to revert that everytime since it brings me additional problems. Do I need to re-configure view depth whenever I want to place such spot?
Am I able to prevent slabs from disappearing from a certain floor plan view when they go below that floor level? (Since they do belong to that floor, I thought they should've kept visible)
Thanks in advance
Architect / BIM Manager at Ideia1 - www.ideia1.com.br
Archicad 24 / Windows 10 64
7 REPLIES 7
Labels
