Story Marker : Staggering, Offset/Move left and right marker
Palawat
Hi everyone,
I've been developing a story marker for months and now it's time for its first release.
Some of the features are ;
Staggering Options
Display Story Name (with or without Story ID), 2 Story Elevations
with separate Reference Levels.
Additional Stories / Levels for extra levels needed to display, without
having to add actual project stories.
Markers on the left and right side can be move(offset) individually for each
story, or using “Batch Offset Distance” tab to offset multiple stories
(base on elevation) at the same time.
see more from the link below
And here are some screen shots,
Download page : https://www.indigofigs.com/story-marker/
(Last Update : 23 Nov. 2017)
Please make sure you read "Environment Settings & Getting Start" also.
___________________________________________________________
Feature Added ;
(20 Nov. 2017) “Custom Overwrite” option will automatically fill the blank field with Project Story Name and Additional Level Name (if set in “Additional Levels Settings …” tab). This is useful when only a minor detail needs to be edited, such as, from “First Floor Plan” to “First Floor Plan (revision 1)” or a special character needs to be issued( \n = new line, \t = tab ).
Change ;
(23 Nov. 2017) Textblock Width and Text Alignments for Story Elevation 1 and Story Elevation 2 are disabled. Their values will be automatically calculated instead.
Bugs fixed ;
(23 Nov. 2017) “Mirror Text Alignment” option for Story Name is not working correctly. Fixed.
(20 Nov. 2017) Marker only works for project with 50 project stories, not 500. Fixed.
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.facebook.com/indigofigs
11 REPLIES 11
alemanda
Thanks a lot for sharing.
It looks quite promising.
However it seems not to be saved as Section Marker nor Elevation marker
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Palawat
Hi alemanda,
Not sure if I understand you correctly, but if I do, that's probably because it's not a "section-elevation marker" subtype. It is "story marker" subtype. So it cannot be saved as section/elevation marker.
After selecting this story marker to use with any of section / elevation, please try to save favorite. The story marker should be saved along with that particular section / elevation settings.
alemanda
... I got it.
Thanks
Win 10 Pro 64bit
www.almadw.it
Palawat
An update is available. Please see the "Logs" on the page for more info.
Just download and replace the old file with the new one.
kmitotk
Thank you for sharing this very well developed GDL. This is much more useful than the built-in story marker.
It works great with ArchiCAD Int. It doesn't, however, seem to work with AC US version, unfortunately. The stories don't show up correctly in the US version, probably because the AC US lacks the story 0.
Would you be able to tweak the script and make it available for the AC US (and other story-0-less AC version) users?
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 26 & 27 JPN USA & INT | Windows 10
Palawat
Hi kmitotk,
I'm not familiar with the US version but I'll take a look.
kmitotk
Great! It would be really appreciated.
The European way of counting the floors is: the ground floor, the 1st floor, the 2nd floor...
In the US, it is: the 1st floor (or the ground floor), the 2nd floor, the 3rd floor...
To accommodate this convention, there is no Story 0 in the story settings in AC US. AC Japanese is also the same way.
Thank you Palawat.
Kei Mito
Palawat
kmitotk, could you please send me your email address via private messaging so I can send you the file to test?
I've added a checkbox on the first tab. This HAS TO BE CHECKED when using with ArchiCad version without zero index story (USA, JP) and HAS TO BE UNCHECKED when using with any version with zero index story.
There is a limitation, though. Working back and forth between different versions (ie, from INT version to USA version, or vise and versa) is NOT seamlessly. All of the custom settings/values will get shifted.
Leire Bilbao
Hello!
I am trying this Story Marker but I am struggling with the prefixes and the overrides.
I want to show an extra level per story, with a different prefix than the story levels:
- the prefix FFL for the level of the story
- the prefix TOC for the Top Of Concrete level
I don't manage to do this. Is it possible?
Also I would like to override the colour of the 0 level (the elevation number) and I only managed to override the name. is it possible?
Thank you very much anyway. It is a nice plug in!!
