Story dimensions in Section
Tom Krowka
Is there any way to display the automatic story levels in sections to display as distances above sea level rather than from the "0" floor level. Does not seem to be any way to set that via the Dimension settings, which appear to control that dimension text variable. Maybe there is another way?
Thanks. Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
David Maudlin
Tom:
Using the Built-In Story Marker, go to Section Settings > Story Levels Symbols and Text > Story Marker Geometry... > Reference Level and set to Sea Level. Sea Level for the project can be set under Project Location...
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Tom:
David
Tom Krowka
Yes, thanks. Obviously I did not search deep enough. Tom
Thomas@wkarchwk.com
www.walshkrowka.com
