2021-10-28 11:49 AM
I have a sun study set up, ask for study of 12/21/2021. I get a video result that seems to be correct, but the time stamp indicates 3/21/2021. Troubleshooting, I configure the study for different dates and never get the correct month (day and year are correct). I can't determine a pattern to the error nor am I sure at the moment if the time stamp is incorrect relative to these path shown, or if the stamp correctly identifies the sun path, but the sun path doesn't match sun study config.
Anyone seen this before?
Archicad 25 (3011)
Mac OS 11.5.2
2021-10-28 01:20 PM - edited 2021-10-28 01:24 PM
I was able to generate the same error. It may something to do with making a Save of the Archicad file between making each new sun study - I am not entirely sure. And it can happen both ways-- using the current date setting can generate the last timestamp date, and the other way around, setting a future date can still generate the current date in the time stamp. I will post some videos when I have more time.
ArchiCAD 25 5010 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2021-10-28 01:35 PM - edited 2021-10-28 01:38 PM
this is a very crude video but it does show the problem can happen
https://www.youtube.com/watch?v=LQ5YKcgXKcM
2021-11-05 06:19 AM
Dear Robert,
Thank you very much for sharing this issue and I am very sorry about it!
From your description, it seems like this is defect DEF-6453. Based on the info of the defect, requesting the same video for the second time with the same parameters seems to solve the issue. Could you please give it a try and let us know if it works?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-12-09 05:14 AM - edited 2021-12-09 05:29 AM
I have sma issue. Your solution worked in AC25EN, on second attampt to save sun study was the date correct. BUt this workaround dont work in AC25CZ.
I shows still the same date: 20.8.2018. I wonder what happened that date 😊
2022-01-10 09:30 AM
Yes, Minh, your work-around produced the correct result. To clarify my original post, it's not the timestamp that is incorrect, it's the requested date is not produced. Archicad makes sun-study based on previously requested parameters, which are correctly reflected in the time stamp. But - sun study is not according to date parameters entered.
2022-05-12 01:36 AM
Hi Minh,
The issue still happens with Archicad 25 4017 NED full. Causing us a lot of problems. In teamwork its not even possible to change the date, only by saving the file locally and making the sun study through that file. Would appreciate a fix, thanks.
2022-06-21 06:02 AM
It seems that DEF 6543 still occurs in the latest update of Archicad 25. Hope to see some bug fixing here. Not being able to change the date in a teamwork project, looks like a 'reserve (all)' issue. Also not user friendly.
With kind regards
Harald Dogge
