TIFF Construction Documentation
ares997
I am trying to publish a Tiff version of a construction documents though when I publish them it shows everything in window versus just the stuff on the sheet. Also the quality is low. Basically I would like to publish a set in it's entirety in a tiff version without loosing quality and not publishing all the information in the window that the sheet exist on.
Is this possible?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
1 REPLY 1
I haven't tried this myself but I would expect the AC output to be low-res. It would probably work best to output PDF and do the conversion in Acrobat or Photoshop.
