Document & Visualize forum
Tags and Categories Label
Does anyone know if you can crop the label so that the description can run across 2 lines rather than 1.
The Text label works fine, however I want to use the Tags and Categories label so it will automatically pick up the information I want displayed from what I am labelling
The attached file shows how I want it to display
1 REPLY 1
ok I finally found it, it is under the dialog box for Text width of Values. Unfortunately I can't find hotspots that can be adjusted similar to the text label nevermind
