Text Tool - Can you add a leader line?
Rachaelp
Hopefully a simple question. Is it possible to add a leader line to the Text Tool within Archicad? Or are leaders only associated to labels?
Thanks!
Only labels have leaders (pointers).
Just use the 'Autotext' label to type any text you want - just as you can for standard text.
You can use standard text and a separate line that you can group together, but it is not the same as a label.
Rachaelp
Thanks Barry.
ryejuan
You also need to be aware that if you are using Labels when you change the scale of your documentation you need to adjust the font size compare to standard text it gives you the ability to select "Model Size" or "Paper Size". hope it helps you.😎
In the end what is your Objective?
ArchiCAD 9 onwards
