Document & Visualize forum
Texts messed up
Dave98
One day i was opening my work files and all texts had moved out of place on plan and layout in every Archicad 23 file. Texts have moved out and under the text block and some have lost width and spacing properties. I suspect this has something to do with my computer because all the files are that way. Tried updating Archicad, reinstalling Archicad, updating my windows and gpu driver. Has anybody had that same problem and how to fix that?
Dave
Windows 10
Archicad 23.0.0.3003
1 ACCEPTED SOLUTION
Solution
Miha_M
My first suspect would be that most likely it's the font which is missing. If you select the text and see the text block font in [brackets], then the used font is not installed.
Archicad 4.55 - 24 | HP Z800 | Dual Xeon X5667 | 48 GB RAM | Nvidia Quadro P1000 @ Windows 10 Pro x64
4 REPLIES 4
Labels
