Document & Visualize forum
Texture issues on angled walls
Design3
Hi there,
I am having issues with my brick texture showing up on an angled wall. Is this a bug with the software or is there way to fix this?? Thanks
ryejuan
Have you check if there are any other elements interacting with the wall?
In the end what is your Objective?
ArchiCAD 9 onwards
DGSketcher
Champion
The image looks overexposed to me, have you considered turning down the light source values?
Does the problem occur with a different AC supplied surface?
It may have something to do with the individual surface settings if this is a custom texture?  Try comparing them with a similar but AC supplied surface.
Apple iMac macOS Monterey / AC26UKI (most recent builds)
