The dimension input becomes strange. I'm trying to hit 1000, but if I hit 100,000, it turns into 10
LeeJaeYoung
I'm trying to hit 1000, but if I hit 100,000, it turns into 10.00?
Even when editing, unexpected dots appear on backspace or del keys. Is it just me?
AC27 on window 11
11 REPLIES 11
However, this kind of mistake can happen often, so please understand. If I bring a translation from translate.google.com and copy it with the translation turned on in Edge to read your answer, the translation will be translated back into Korean and saved. This is a phenomenon that occurs when I forget to turn off edge translation when saving. However, sometimes it is saved without being retranslated into Korean. ^^
Looking forward to your generous forgiveness...
AC27 on window 11
It is not a problem.
You usually do a very good job at translating.
Usually we will just remove a foreign language post but I thought you should have the chance to translate it first.
I have removed it now that you have provided the translation.
Thank you.
