Title Sheet Issue
I created two new Title Sheets (Architectural D, and Ledger sizes) in the Master Layout to use as my Master Title Sheets. However when I go into another project file I cannot find it in that list of Titles in the Master listing. The only Title Sheets in those files are the standard Title sheets that came with ArchiCAD. If I go back into the project where I created it , they are there. Why can't see or access them in other project files?
1 REPLY 1
vistasp
Welcome to the forums, TSquare360.
Master layouts can be part of your template, in which case they will be available to you in any project file based on that template.
In your current scenario, you'll have to use the Organizer to import them into the new file.
https://helpcenter.graphisoft.com/user-guide/76329/
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
