Document & Visualize forum
Tracing over a trace refererence
KeesW
I am having to draw over PDF plans to create copies. I've set the PDF dwg as a trace reference so that I can draw over the top of them using the Archicad wall, door, window, tools. But I can only use some 2D tools such as lines and circles. If I try to trace over a 300 thick wall on the trace reference, with a new 300 thick wall, it doesn't work. That can't be right, surely because it is called a trace tool. What am I doing wrong?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Are you by chance trying to model in a detail or worksheet window?
These are only 2D which is why you can only use 2D tools.
You should have no problem tracing in the floor plan.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
4 REPLIES 4
Versions 6.5 to 25
Yes that was it. Thank you Barry. I thought that I'd be clever and put the drawing I was tracing into a worksheet.
You can put the drawing in a worksheet.
You then reference the worksheet from the plan view - rather than putting the drawing in the plan view itself.
Or place it in another storey and reference that storey.
Versions 6.5 to 25
ryejuan
also check the scale of the drawing you are tracing.
In the end what is your Objective?
ArchiCAD 9 onwards
