Transparent Railings
Festim Idrizi
Dear Community,
I was trying to make these type of railing into Elevation. Railings is made by a material, no matter what I tried I can't make it transparent.
P.s Transparency is ON.
I would like to make the Railing to be shown just like the hatch is, but I just can't achieve it.
Anyone has an Idea it would be really helpfull.
Best,
`Railing 1.pngHatch vs RailingHatch vs Railing
Gelander ElevationGelander Elevation
Turit
Set the used railing surface transparency 51% or more, and the elevation settings be transparency  on. (Under 50 % will be solid)
Turit
Festim Idrizi
Thanks Mr. Turit,
It did work, but the problem is that in 3D it shows like a glass now. Because I wanted full transparency, and not just for the lines.
