2022-10-14 08:54 AM
Dear Community,
I was trying to make these type of railing into Elevation. Railings is made by a material, no matter what I tried I can't make it transparent.
P.s Transparency is ON.
I would like to make the Railing to be shown just like the hatch is, but I just can't achieve it.
Anyone has an Idea it would be really helpfull.
Best,
Hatch vs Railing
Gelander Elevation
Solved! Go to Solution.
2022-10-15 02:46 AM
Set the used railing surface transparency 51% or more, and the elevation settings be transparency on. (Under 50 % will be solid)
2022-10-17 08:24 AM
Thanks Mr. Turit,
It did work, but the problem is that in 3D it shows like a glass now. Because I wanted full transparency, and not just for the lines.
