Document & Visualize forum
Transparent objects in interior elevations
Hello!
Is there any way to make 'object' fills transparent in 2D interior elevation views?
Goal is to see bathroom tile layouts + an outline of sink, bathtub etc. It seems to work in plan view, but not in elevation. Can't seem to get it working with override settings or elevation view settings. Attached some screenshots.
Lingwisyer
Elevations use the 3D properties of an object, so you could try overriding the materials of your fixtures to be air or something similar.
Ling.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Lingwisyer
Ling.
AC18-23 AUS 7000
Alright! I had tried with glass before, which didn't make it fully transparent. But now, with ''air'' it works perfectly. Thank you.
