Visualization
Twinmotion - 2019 library (plants) missing from newer 2020.2 version
Any twinmotion users in here?
Im used to using the plants in twinmotion 2019 and since upgrading to 2020.2 i noticed a lot of the good plant objects are no longer in the library
Anyone know if it is possible to export out or re-import in the plant objects from 2019 into 2020.2?
1 REPLY 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Jason,
Thank you for the question!
Unfortunately, as far as I know, there is no way to import library from Twinmotion 2019 to 2020. Since Twinmotion is developed by Epic Games, I would suggest sharing your request directly to Twinmotion support here: https://twinmotionhelp.epicgames.com/s/
Thank you very much for your understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Learn and get certified!
