2020-07-17 06:16 AM
Solved! Go to Solution.
2020-07-17 09:50 AM
2020-07-17 03:46 PM
2020-07-20 12:15 PM
Scott wrote:It's not available yet. However, I would recommend not waiting for it and just proceed by saving out an FBX file from ArchiCAD (use the "Save As" Twinmotion) option from the 3D window. The previous direct links were very buggy at best and caused a lot of crashes.
Is Twinmotion Direct available for Archicad 24 and if so where is it? Thanks, Scott
2020-07-21 02:37 PM
2020-07-24 09:53 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-10 06:39 PM
2020-08-11 01:02 AM
2020-08-11 02:55 AM
2020-08-11 09:34 PM
Carstenem wrote:To clarify: it does seem to work for both 2020.1 and 2020.2 ... the issue is it displays a warning to update the plug-in every time AC is launched. Hopefully the update check error is the only bug / issue - so please DO test as you have some real models that could stress test it.
Thanks for the heads up saves me testing it out !
