If they are slabs, then select one and using the pet palette options you can add an area to that slab .
Add the area described by the second slab - either by manually picking its nodes or by magic wanding on it.
Then you have to delete the second slab - it does not merge them.
Or just manually adjust the edges and nodes of one of the slabs and delete the other.
Unfortunately there is no way to merge two slabs.
