Ungrouping objects
dhnguyen
Lately I have been having problems where objects that I've grouped but I'm not able to ungroup them unless I copy them into a different files and ungroup them in order to bring them back to my original file... Is there some settings I need to change?
I have "reserved all" in order to see if that might change, but it doesn't.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Check that the layer or objects are not locked in the original file.
dhnguyen
awesome, thank you!
DNguyen
ArchiCAD 18- 25
