Unstable Label Tool
This label tool seems very unstable. The correct way is shown below, but it changes to the incorrect way shown on the top. How can we fix this. It happened in previous version of Archicad and it is happening in 24.
Minh Nguyen
Hi Cheikh,
Thank you for the question and I am sorry about the issue!
Have you checked out this thread: https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70555
The symptom seems to be similar to this one. I suggest open the file using Open & Repair function to fix the issue. Please let me know if this helps!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thank you Minh. It solved the problem.
