Visualization
Using the lightworks Archives and image files in textures
I have been watching some older tutorials (ac v9 and v10) that show how to use lightworks to achieve great results for rendering. I was particularly interested in the billboard trees (walls that carry a tree image and display themselves in render as trees) especially because rendering leaves can be very heavy processing. So I downloaded the free archive files at
http://www.lightworks-user.com
and have been trying for what seems an age to use a tree texture on my wall. In the tutorial there is an "opacity file" (an alpha transperancy file that you get with say a .tif image or when you use the alpha channel in photoshop). These trees do not have the opacity file. I have played with endless combinations of settings to see my trees on the billboards, but I only get either a faded shadowy tree (barely visible) or a great looking tree but with all the black on the billboard behind. If anyone has used these trees could you send me some advice please!
Thanks
Xanthia
You gotta make the alpha in photoshop (or CorelDRAW) and then edit the texture to include the alpha.
Alternatively: make the background transparent and save the image as .png. Then load into your project using Library manager and apply to the library part People Bitmap as a custom image.
Thanks...
Yes I did get that, my problem was that I had a .lwi file, inside a .lwa archive and couldnt get them out to make that alpha transperancy, or save them, or even see their size or anything. I have found a suitable library object that I can use now... too much banging my head against a brick wall...
Again... thanks heaps for replying
