Vectorial in elevation 21
ROBERT ACTON
Beginner
Hi, I'm new to AC21, after being on AC13 for many years I am adjusting ..?
I am trying to show vectorial hatching in elevation and section with no colour, just line work. Also, can I get the Vectorial hatching to show in White Model with Shadows mode. Any quick tips?
In the elevation/section settings ...
Vectorial hatching can only show in 3D if you are using the vectorial engine - not Open GL.
ROBERT ACTON
Beginner
Thanks Barry, I didn't know I had to hit the Vectorial engine button. Its definitely a lot different to 13.
Now I just need to get the shadows back, its reverted to just a contour line... what did I click for that to happen?
In '3D Styles' where you set the OpenGL or Vectorial Engine, there are all the options for contours, shadows, etc.
These can now be saved as a 'style' (combination) to make it easier to change the settings and the style is also saved with each 3D view in the view map.
