2017-02-14 11:19 AM
2017-02-16 01:43 PM
2017-03-17 11:16 AM
2017-03-17 11:19 AM
2017-04-16 11:28 PM
2017-04-17 05:28 AM
In the meantime, you can activate the saved View, then go back to the Floor Plan, move the Camera, then right-click the Camera and Show All in 3D.
The 3D View is changed in its TAB. Right-click the TAB and click the Save View command. This way the View will be updated with the new Camera location.
2022-08-16 01:20 AM
Does anyone know if this issue is still going to be fixed? 🤔
In Archicad 24 and 26, it appears to still be broken. There is that work around with more clicks mentioned above, but when adding in new cameras/modifying views (especially internal cameras) constantly, it is quite a pain for it to not automatically take effect in the View map.
Thanks!
2018-05-26 10:19 AM
2019-01-16 01:05 AM
2020-03-19 01:24 PM
2022-06-06 07:17 PM
Hi I'm running into this same problem in AC25 - has this been fixed??
