WALLS -- How to configure uncut lines different to cut lines
I hope its an easy question. It should be. But I dont seem to find the way to do it.
I simply want to display UNCUT lines thinner than CUT lines. See attached.
How can I configure that in Graphic Override Rules?
Thanks a lot.
Lingwisyer
Guru
Looks as if you have a detailed fascia with lines merging into each other... Also, why not just used the objects cut and uncut linetype settings? Why GOs?
I don know about merging fascias (quite new to AC), but it happens to all UNCUT lines. I would like to be able to switch between different graphic styles via G.O. rather than lines per object.
I just want something very basic in architectural representation, which is to differentiate between cut and view lines.
Many thanks
DGSketcher
Legend
Have a look at the Elevation / Section settings where you can set the Cut & Uncut line pen for the view.
https://helpcenter.graphisoft.com/user-guide/77566/
