Wall End Tool Fill is Not a Cut Fill
genarch
Mac OSX 11.6.8
AC26, Artlantis 2020, TwinMotion
iMac Pro 2017 / 8-core 3.2 GHz / 32GB RAM
genarch
Dang it, a big menu popped up showing me similar posts and I couldn't get rid of it. Anyway, the fill for the Wall End tool is a drafting fill instead of a cut fill so when you set a Graphic Override for no cut fills the Wall Ends will still have their fills.
Mac OSX 11.6.8
Thank you very much for the question!
I tried to reproduce the issue on Archicad 25, but the Wall End was overridden correctly with the Cut Fill option via Graphic Override rule.
Could you please share some screenshot of the rules you used and the object's settings for a closer look?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
